17" Unibody Late 2011 Parts
The Late 2011 version of MacBook Pro 17" Unibody is virtually identical to the Early 2011 model except for a CPU and graphics upgrade. It features a quad core Core i7 processor with PC3-10600 RAM. It also sports the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The MBP 17" Unibody (Late 2011) is a solid laptop right out of the box, but it can be upgraded with as much as 16 GB of PC3-10600 RAM in its 2 RAM slots. The 750 GB 7200 RPM SATA hard drive will give you plenty of storage.
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$149.95
120 GB Solid State Drive Upgrade Kit
Unformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files.
$209.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
750 GB Hybrid Seagate SATA Hard Drive (New)
SSD speeds from the Momentus XT Hybrid Drive.
$199.95
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD
$199.95
PC3-10600 8 GB RAM Chip
RAM Upgrade / 8 GB / PC3-10600 / Low Profile / 204 pin, 1333 MHz
$149.95
500 GB Hybrid Seagate SATA Hard Drive
$139.95
1 TB 5400 RPM Toshiba SATA Hard Drive (New)
SATA interface for Intel Macs / Toshiba / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM
$129.95
750 GB 7200 RPM Seagate SATA Hard Drive (New)
$129.95
Unibody 8x SATA SuperDrive (Post-Early 2009)
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write
$109.95
