15" Unibody Mid 2010 Parts
The Mid 2010 version of MacBook Pro 15" Unibody features an upgraded graphics chip, new Core i5 or Core i7 processors, and a hefty internal battery that boasts up to 9 hours of life between charges!
The MBP 15" Unibody (Mid 2010) is a solid laptop right out of the box, but it can be upgraded with as much as 8 GB of PC3-8500 RAM into its 2 RAM slots. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 50
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $149.95 |
| | MacBook Pro 15" Unibody (Mid 2010) 2.53 GHz Logic Board2.53 GHz Core i5 Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out | $999.95 |
| | MacBook Pro 15" Unibody (Mid 2010) 2.4 GHz Logic Board2.4 GHz Core i5 Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out | $899.95 |
| | MacBook Pro 15" Unibody (Mid 2010) Display AssemblyIncludes LED assembly and iSight camera. | $499.95 |
| | MacBook Pro 15" Unibody (Mid 2010) Upper CaseCase Assembly includes backlit keyboard and trackpad assembly. | $329.95 |
| | 120 GB Solid State Drive Upgrade KitUnformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files. | $209.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
| | 15" Unibody LCD PanelReplacement display panel for 15.4" Unibody displays. | $169.95–$199.95 |
| | MacBook Pro 15" Unibody (Mid 2010/Early 2011/Late 2011) Lower CaseReplace a scratched-up lower case | $199.95 |
| | MacBook Pro 15" Unibody (Mid 2009/Mid 2010/Early 2011/Late 2011) 8x SATA SuperDrive (Used)DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write | $199.95 |
