15" Unibody Late 2008 Parts
Apple released the MacBook Pro 15" Unibody with a new aluminum case drilled from a single aluminum brick.
The MBP 15" Unibody (Late 2008) can use a 4 GB RAM chip and a 2 GB RAM chip for a total of 6 GB to maximize the performance of this notebook. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$219.95
MacBook Pro 15" Unibody (Late 2008) 2.8 GHz Logic Board
2.8 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, Audio In, Audio Out
$999.95
MacBook Pro 15" Unibody (Late 2008/Early 2009) 2.4 GHz Logic Board
2.4 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, Audio In, Audio Out
$799.95
MacBook Pro 15" Unibody (Late 2008/Early 2009) Display Assembly
Includes LED assembly, iSight Camera, Bluetooth Card, and AirPort Card.
$699.95
MacBook Pro 15" Unibody (Late 2008/Early 2009) Upper Case
Case Assembly includes backlit keyboard and trackpad assembly.
$299.95
750 GB Hybrid Seagate SATA Hard Drive
SSD speeds from the Momentus XT Hybrid Drive.
$249.95
1 TB 5400 RPM Samsung SATA Hard Drive (New)
SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM
$249.95
120 GB Solid State Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD
$229.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
15" Unibody LCD Panel
Replacement display panel for 15.4" Unibody displays.
$169.95–$199.95
