15" Unibody Early 2011 Parts
The Early 2011 version of MacBook Pro 15" Unibody features an upgraded graphics chip and a new quad core Core i7 processor with PC3-10600 RAM. The Mini DisplayPort was also replaced (but still backwards compatible) with the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The MBP 15" Unibody (Early 2011) is a solid laptop right out of the box, but it can be upgraded with as much as 16 GB of PC3-10600 RAM into its 2 RAM slots. The 750 GB 7200 RPM SATA hard drive will give you plenty of storage.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 51
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $149.95 |
| | MacBook Pro 15" Unibody (Late 2011) 2.2 GHz Logic Board2.2 GHz Core i7 Motherboard / Ports: Thuderbolt (Mini DisplayPort), 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out | $999.95 |
| | MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board2.0 GHz Core i7 Motherboard / Ports: Thuderbolt (Mini DisplayPort), 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out | $899.95 |
| | MacBook Pro 15" Unibody (Early 2011/Late 2011) Display AssemblyIncludes LED assembly and iSight camera. | $649.95–$749.95 |
| | MacBook Pro 15" Unibody (Early 2011/Late 2011) Upper CaseCase Assembly includes backlit keyboard and trackpad assembly. | $299.95 |
| | 120 GB Solid State Drive Upgrade KitUnformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files. | $209.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
| | 15" Unibody LCD PanelReplacement display panel for 15.4" Unibody displays. | $169.95–$199.95 |
| | MacBook Pro 15" Unibody (Mid 2010/Early 2011/Late 2011) Lower CaseReplace a scratched-up lower case | $199.95 |
| | MacBook Pro 15" Unibody (Mid 2009/Mid 2010/Early 2011/Late 2011) 8x SATA SuperDrive (Used)DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write | $199.95 |
