15" Unibody 2.53 GHz Mid 2009 Parts
The 2.53 GHz Mid 2009 version of the MacBook Pro 15" Unibody shares more in common with the MBP 13" Unibody than other MBP 15" Unibody models. The 2.53 GHz machine features a single fan and graphics chip with shared memory.
The MBP 15" Unibody 2.53 GHz (Mid 2009) can be upgraded with as much as 8 GB of PC3-8500 RAM into its 2 RAM slots. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 55
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $219.95 |
| | MacBook Pro 15" Unibody (Mid 2009) Anti-Glare Display AssemblyIncludes LED assembly, iSight camera, and AirPort card. | $899.95 |
| | MacBook Pro 15" Unibody (Mid 2009) 2.53 GHz Logic Board2.53 GHz Motherboard / Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, SD card slot, Audio In, Audio Out | $849.95 |
| | MacBook Pro 15" Unibody (Mid 2009) Display AssemblyIncludes LED assembly, iSight camera, Bluetooth board, and AirPort card. | $699.95 |
| | MacBook Pro 15" Unibody (Mid 2009) Anti-Glare Upper CaseCase Assembly includes backlit keyboard and trackpad assembly. | $299.95 |
| | MacBook Pro 15" Unibody (Mid 2009) Upper CaseCase Assembly includes backlit keyboard and trackpad assembly. | $299.95 |
| | 750 GB Hybrid Seagate SATA Hard DriveSSD speeds from the Momentus XT Hybrid Drive. | $249.95 |
| | 1 TB 5400 RPM Samsung SATA Hard Drive (New)SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM | $249.95 |
| | 120 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD | $229.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
