MacBook Pro 15" Unibody (Late 2008 or Early 2009) Parts
Apple released the MacBook Pro 15" Unibody in late 2008 with a new aluminum case drilled from a single aluminum brick. A quiet speed bump in early 2009 made these machines even more powerful!
These machines can be upgraded with a hefty, yet agile 500 GB 7200 RPM SATA hard drive.
Select your model above for parts and assistance!
Results
Showing products 1 - 10 of 60
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $149.95 |
| | MacBook Pro 15" Unibody (Late 2008) 2.8 GHz Logic Board2.8 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, Audio In, Audio Out | $999.95 |
| | MacBook Pro 15" Unibody (Late 2008/Early 2009) 2.4 GHz Logic Board2.4 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, Audio In, Audio Out | $799.95 |
| | MacBook Pro 15" Unibody (Late 2008/Early 2009) Display AssemblyIncludes LED assembly, iSight Camera, Bluetooth Card, and AirPort Card. | $599.95–$699.95 |
| | MacBook Pro 15" Unibody (Late 2008/Early 2009) Upper CaseCase Assembly includes backlit keyboard and trackpad assembly. | $299.95 |
| | 256 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 256 GB Unformatted / SSD | $249.95 |
| | 240 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 240 GB Unformatted / SSD | $229.95 |
| | 15" Unibody LCD PanelReplacement display panel for 15.4" Unibody displays. | $169.95–$199.95 |
| | 750 GB Hybrid Seagate SATA Hard Drive (New)SSD speeds from the Momentus XT Hybrid Drive. | $199.95 |
| | 120 GB Solid State Drive Upgrade KitUnformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files. | $179.95 |
