MacBook Pro 13" Unibody Mid 2009 Parts
In Mid 2009, Apple brought back the Firewire 800 port. They also added an SD card slot and increased the processor speed.
The Mid 2009 MacBook Pro 13" Unibody can be upgraded with up to 8 GB of PC3-8500 RAM. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 56
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $149.95 |
| | MacBook Pro 13" Unibody (Model A1278) 2.53 GHz Logic Board2.53 GHz Motherboard / Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot | $849.95 |
| | MacBook Pro 13" Unibody (Model A1278) 2.26 GHz Logic Board2.26 GHz Motherboard / Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot | $649.95 |
| | MacBook Pro 13" Unibody (Model A1278 Mid 2009/Mid 2010) Display AssemblyIncludes LED assembly, iSight camera, Bluetooth card, and AirPort card. | $499.95 |
| | MacBook Pro 13" Unibody (Model A1278 Mid 2009/Mid 2010) Upper CaseCase assembly includes backlit keyboard. | $299.95 |
| | 256 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 256 GB Unformatted / SSD | $249.95 |
| | 240 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 240 GB Unformatted / SSD | $229.95 |
| | 750 GB Hybrid Seagate SATA Hard Drive (New)SSD speeds from the Momentus XT Hybrid Drive. | $199.95 |
| | 120 GB Solid State Drive Upgrade KitUnformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files. | $179.95 |
| | 120 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD | $169.95 |
