MacBook Air 13" (Late 2008) Parts
The Late 2008 version of the MacBook Air features an updated system bus to 1066 MHZ and faster NVIDIA graphics. Also new is a switch to the Apple-standard Mini DisplayPort.
Internet troubles? Try replacing your AirPort/Bluetooth board using our free repair guide!
Power issues? Try a replacement 45-watt AC Adapter.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 34
| | MacBook Air 1.6 GHz (Late 2008) Logic Board1.6 GHz Motherboard. Includes 2 GB of RAM | $599.95 |
| | MacBook Air Display Assembly1280x800 LCD / 13.3" | $599.95 |
| | MacBook Air (Late 2008/Mid 2009) 128 GB SSD, Bracket, and Cable UpgradeUpgrade to an SSD with this 128 GB Solid State Drive, plastic bracket, and cable for the MacBook Air. | $499.95 |
| | MacBook Air (Late 2008/Mid 2009) 120 GB Hard DriveSamsung / 1.8" form factor / 5mm thick / 120 GB Unformatted / 4200 RPM | $279.95 |
| | MacBook Air (Late 2008/Mid 2009) Upper Case with KeyboardUpper case includes keyboard, palmrest area, trackpad, power button, and trackpad control board. | $199.95 |
| | MacBook Air (Late 2008/Mid 2009) Lower CaseReplace a scratched-up lower case | $149.95 |
| | MacBook Air AirPort/Bluetooth Board802.11n AirPort wireless / Bluetooth 2.1 internal card | $149.95 |
| | MacBook Air (Mid 2009) BatteryUpgrade your aging battery | $109.95 |
| | MacBook Air (Original/Late 2008) BatteryApple Original OEM Battery | $99.95 |
| | MacBook Air (Late 2008/Mid 2009) Port Hatch AssemblyIncludes USB 2.0, Mini DisplayPort, and audio out ports | $99.95 |
