MacBook 13" Unibody (Model A1342) Late 2009 Parts
In October 2009, Apple revamped the low-end MacBook to fit the unibody lineup. Retaining its polycarbonate casing, the new MacBook Unibody features an internal battery, a rubberized lower case, and an LED display. Apple also removed Firewire from the MacBook line. The Macbook 13" Unibody (Late 2009) can be upgraded to a total of of 8GB of RAM using two 4GB RAM chips.
Select a category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$149.95
MacBook Unibody (Model No. A1342) 2.4 GHz Logic Board
2.4 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out
$749.95
MacBook Unibody (Model No. A1342) 2.26 GHz Logic Board
2.26 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out
$599.95
MacBook Unibody (Model No. A1342) Display Assembly
Includes LED assembly and iSight Camera.
$399.95–$499.95
120 GB Solid State Drive Upgrade Kit
Unformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files.
$209.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
MacBook Unibody (Model No. A1342) 8x SATA SuperDrive (Used)
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write
$199.95
750 GB Hybrid Seagate SATA Hard Drive (New)
SSD speeds from the Momentus XT Hybrid Drive.
$199.95
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD
$199.95
13" Unibody LCD Panel
Glossy or anti-glare display panels for MacBook Unibody and MacBook Pro Unibody 13.3" displays.
$109.95–$149.95
