MacBook 13" Core 2 Duo Parts
The Core 2 Duo MacBooks feature beefier processors, thanks to the Core 2 Duo chipset.
A total of 3 GB of memory (using a 2 GB RAM chip and a 1 GB RAM chip) will max out your machine's capacity. The biggest hard drive that can currently be put into these laptops is the 500 GB 7200 RPM SATA hard drive. The 8x SuperDrive is the fastest optical drive for these models and will make creating DVDs a whiz. You can also upgrade the upper case to the Penryn/Santa Rosa version with the new keyboard layout (including iTunes controls)!
There is one main variation within these models. Your machine may be a Energy Star-equipped or non-Energy star version. This affects the battery connector and logic board. See photos and part descriptions on the non-Energy Star or Energy Star battery connector/sleep sensors for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your model above or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 76
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $149.95 |
| | MacBook Core 2 Duo 2.16 GHz (non-Energy Star) Logic Board2.16 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $499.95 |
| | MacBook 13.3" Core 2 Duo Display Assembly1280x800 LCD / 13.3" | $299.95–$499.95 |
| | MacBook Core 2 Duo 2 GHz (non-Energy Star) Logic Board2 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $399.95 |
| | MacBook Core 2 Duo 1.83 GHz Logic Board1.83 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $349.95 |
| | 120 GB Solid State Drive Upgrade KitUnformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files. | $209.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
| | MacBook 13.3" LCD PanelLCD without the display bezels, hinges, hinge mount or cables / 1280x800 LCD / 13.3" | $149.95–$199.95 |
| | MacBook 8x SuperDrive (Used)DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 8x DVD+R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write | $199.95 |
| | MacBook/MacBook Pro 15" 8x SuperDriveDVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 8x DVD+R write, 4x DVD-RW write, 24x CD-R write, 24x CD-RW write | $149.95 |
