Permissions and Patrolling
Overview of Permissions and Patrolling ¶
Permissions 101 ¶
It is important that it be super easy to contribute step-by-step guides for new kinds of things, and make modifications to them. That's why Wikipedia works so well— they accept any and all edits, and then filter them after the fact.
The problem is that these two goals—protecting high-quality existing content and encouraging laissez-faire contributions—are diametrically opposed. With this permissions system, original authors of content can set a minimum reputation limit on wiki-content they publish. This is primarily in place to reduce vandalism or unwanted changes to wiki-content.
Every wiki and guide has a permissions section. Administrators determine how much reputation is required to edit the page without permission. If someone with low reputation (other than the page creator or a member of the creator's team) edits the page, then the edit is not immediately published. An admin or user with enough reputation must approve the edits before they go live.
How to Set Permissions ¶
Only administrators are able to set permissions. For everyone else, the permission section is automatically set by the system. To set permissions for a page, press the Edit tab at the top right of the browser on a page. Now look at the right side of the browser again; here you will find the Edit Permissions meter:
From here you can choose what minimum reputation will allow for automatically updated edits. Either slide the slider, or enter the desired number. Be sure to hit save next to the slider, as well as at the bottom of the page to commit these changes.
Explanation of Permission Values:
  • 0 - No minimum value, no edits require reputation for approval
  • # - Edits from people with reputation below # require permission for approval (unless made by the guide creator or a member of the creator's team)
  • - Admin Only, all other edits must be approved.
Say the permissions value is set to 1000. A member with 1500 reputation could freely edit the page and those edits would immediately go live on the site. If someone with 500 reputation made an edit, their edit would be held for review. Until the edit is approved, whenever another person goes to view that page there a link at the top that lets the user view either the latest version with "Unverified edits" or the "Last verified snapshot." At the same time, these changes are added to the permission edits page. Experienced folks (or admins) can then come along and 'patrol' these proposed changes, approving and denying them as deemed appropriate.
For more information on how to patrol changes, check out the Permissions Manager page.
Go back to the Help Index
Was this article helpful to you?
Yes
No
Didn't find the answer you were looking for? Ask a Question
