why! WDi7SSD Replace processor (CPU)
  1. why! WDi7SSD Replace processor (CPU), why! WDi7SSD Opening procedure: step 1, image 1 of 3 why! WDi7SSD Replace processor (CPU), why! WDi7SSD Opening procedure: step 1, image 2 of 3 why! WDi7SSD Replace processor (CPU), why! WDi7SSD Opening procedure: step 1, image 3 of 3
    • Make sure the computer is disconnected from the power source.
    • Flip the computer over.
    • Remove the six screws with a 2 mm Allen key.
    • Carefully remove the back panel, as well the left and right panel.
  2. why! WDi7SSD Replace processor (CPU): step 2, image 1 of 1
    • Now flip up the base panel to which all components are attached.
  3. why! WDi7SSD Replace processor (CPU), Processor (CPU): step 3, image 1 of 3 why! WDi7SSD Replace processor (CPU), Processor (CPU): step 3, image 2 of 3 why! WDi7SSD Replace processor (CPU), Processor (CPU): step 3, image 3 of 3
    • Loosen the 4 PH2 Phillips screws of the heat sink.
    • Now remove the heat sink.
  4. why! WDi7SSD Replace processor (CPU): step 4, image 1 of 2 why! WDi7SSD Replace processor (CPU): step 4, image 2 of 2
    • Use the screwdriver to unscrew the three PH2 slotted screws to release the CPU holder.
    • Press down the spring on the right side of the CPU and pull it carefully to the side.
    • Put the CPU aside.
    • To remove the thermal paste, you can use isopropanol. The thermal paste must be completely removed from the heatsink and CPU.
To reassemble the unit, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
30,908 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 13
All Time: 146
