uAttend bn6000 Screen Replacement
  1. uAttend bn6000 Screen Replacement, Disassembly: step 1, image 1 of 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Screen Replacement: step 2, image 1 of 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Screen Replacement, Screen: step 3, image 1 of 2 uAttend bn6000 Screen Replacement, Screen: step 3, image 2 of 2
    • Remove the four 10mm PH #2 screws from the screen assembly, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the screen assembly from the housing by pulling the screen up and away from the housing.
  4. uAttend bn6000 Screen Replacement: step 4, image 1 of 3 uAttend bn6000 Screen Replacement: step 4, image 2 of 3 uAttend bn6000 Screen Replacement: step 4, image 3 of 3
    • Disconnect the ZIF connector, by using the plastic opening tool to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 316
