uAttend bn6000 Fingerprint Replacement
  1. uAttend bn6000 Fingerprint Replacement, Disassembly: step 1, image 1 of 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Fingerprint Replacement: step 2, image 1 of 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Fingerprint Replacement, Fingerprint: step 3, image 1 of 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: step 3, image 2 of 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: step 3, image 3 of 3
    • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
  4. uAttend bn6000 Fingerprint Replacement: step 4, image 1 of 3 uAttend bn6000 Fingerprint Replacement: step 4, image 2 of 3 uAttend bn6000 Fingerprint Replacement: step 4, image 3 of 3
    • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
To reassemble , follow these instructions in reverse order.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 529
