samsung x820 LCD Replacement
  1. samsung x820 LCD Replacement, LCD: step 1, image 1 of 3 samsung x820 LCD Replacement, LCD: step 1, image 2 of 3 samsung x820 LCD Replacement, LCD: step 1, image 3 of 3
    • samsung sgh x820
  2. samsung x820 LCD Replacement: step 2, image 1 of 3 samsung x820 LCD Replacement: step 2, image 2 of 3 samsung x820 LCD Replacement: step 2, image 3 of 3
    • after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
  3. samsung x820 LCD Replacement: step 3, image 1 of 3 samsung x820 LCD Replacement: step 3, image 2 of 3 samsung x820 LCD Replacement: step 3, image 3 of 3
    • now we have two more screws hiden
    • first time i used needle. this time i took a blade.
    • removing the last two philipps-head screws.
  4. samsung x820 LCD Replacement: step 4, image 1 of 1
    • be carefull. the phone is thin and you should push on two hooks two open cover case.
  5. samsung x820 LCD Replacement: step 5, image 1 of 1
    • now you should take of the square metal in the middle of your phone to eject display.
    • i used plastic spudger
  6. samsung x820 LCD Replacement: step 6, image 1 of 1
    • the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
3 other people completed this guide.
sergeygraf
161 Reputation
1 Guide authored
One Comment
How can I fix with button cos it is damaged
Tangkidos Hagame - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,564
