ilo 1Gb Mp3 Player SD Card Replacement
  1. ilo 1Gb Mp3 Player SD Card Replacement, Belt Clip: step 1, image 1 of 2 ilo 1Gb Mp3 Player SD Card Replacement, Belt Clip: step 1, image 2 of 2
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. ilo 1Gb Mp3 Player SD Card Replacement, Battery Cover: step 2, image 1 of 3 ilo 1Gb Mp3 Player SD Card Replacement, Battery Cover: step 2, image 2 of 3 ilo 1Gb Mp3 Player SD Card Replacement, Battery Cover: step 2, image 3 of 3
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
  3. ilo 1Gb Mp3 Player SD Card Replacement, Battery: step 3, image 1 of 2 ilo 1Gb Mp3 Player SD Card Replacement, Battery: step 3, image 2 of 2
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
  4. ilo 1Gb Mp3 Player SD Card Replacement, SD Card: step 4, image 1 of 2 ilo 1Gb Mp3 Player SD Card Replacement, SD Card: step 4, image 2 of 2
    • The SD Card slot is located under the battery case indicated here.
    • The SD Card Slides into the slot as depicted in the photo and on the indicator above the slot.
    • The ilo 1Gb Mp3 Player was only designed to accept SD Cards of 512mb or lower.
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 425
