Image #1 Image #2
Add Note Edit Step 9 — Display  ¶
  • Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
  • Pry up along the lower edge of the display enough to grab it with your fingers.
Image #1
Add Note Edit Step 10  ¶
  • Lift the display up from its lower edge and rotate it toward the top of the Touch.
  • The next few steps require removal of components under where the display normally sits. Be sure to hold the display to avoid putting tension on the delicate display ribbon cable.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • While holding the display with one hand, run an iPod opening tool down the two long edges of the mylar reflector attached to the metal display tray.
  • When it is sufficiently free from the display tray, remove the mylar reflector from the Touch.
Image #1
Add Note Edit Step 12  ¶
  • Remove the seven Phillips screws securing the metal display tray to the rear panel.
  • The two darker screws belong in the two holes in the tray nearest the bottom edge of the Touch.
Image #1
Add Note Edit Step 13  ¶
  • Lay the display back down into its tray.
  • Remove the final Phillips screw securing the metal tray to the rear panel.
Image #1
Add Note Edit Step 14  ¶
  • Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
  • Use an iPod opening tool to lift the metal display tray and rotate it up toward the top edge of the Touch.
Image #1
Add Note Edit Step 15  ¶
  • Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
  • Leave the copper tape attached to the metal display tray.
Image #1
Add Note Edit Step 16  ¶
  • Use an iPod opening tool to pry the display cable connector up off its socket on the logic board.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Metal Spudger
Soldering Station
$24.95 · 12 In stock
Lead-Free Solder
Related Products
iPod Touch Gen 2 Replacement Battery
$14.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
