Introduction
This guide shows how to replace the iPod Video's logic board.
Insert the iPod opening tool into the left side of the iPod, with the edge of the tool pointing towards the metal back.
A small guitar pick can be extremely helpful in opening the iPod. Simply insert it and slide the pick around the case to free the clips to streamline the process.
Gently enlarge the existing crevice by wiggling the iPod opening tool and moving it to the left.
Continue doing so until the entire side of the iPod is loose.
You can then insert an iPod opening tool to the right of the Hold button. Be very careful while inserting the tool, as the display is very fragile.
Gently glide the iPod opening tool on the top of the display, making sure to free the retaining clips.
The other sides of the iPod should now easily come loose. If they do not, use iPod opening tools on the right side of the iPod in the same way as on the left side of the iPod.
Separate the front of the iPod from the back about an inch (or a couple of centimeters).
Tool used on this step:Tweezers$4.99
Use angled tweezers or an iPod opening tool to slide up the brown connector latch, holding the orange battery ribbon cable in place. Make sure you pull from both sides of the latch. You only need to lift the brown connector latch up about 1-2mm to free the cable. Do not lift more or remove the latch, or you might pull the white connector with it!
Remove the cable from the connector.
Use a small iPod opening tool to release the black hinge holding the hard drive ribbon cable. The tab will rotate up 90 degrees towards the logic board, releasing the ribbon cable.
Use your forefinger to hold the ribbon cable in place; disconnect the drive from the ribbon cable.
Remove the three black Phillips screws securing the front panel to the metal framework.
Rotate the iPod laterally 180 degrees and remove the three black Phillips screws securing the front panel to the metal framework on the other side.
Rotate the iPod so the black plastic tab is more accessible to you.
Use a small iPod opening tool (or your fingernail) to flip up the black plastic tab holding the display ribbon in place. The tab will rotate up 90 degrees towards the display, releasing the ribbon cable.
Use your finger to prevent the cable from lifting upwards. Wiggle the display loose from the frame, and then pull it gently outwards to release the display's ribbon cable. You may need to lift the cable away from the two white pegs that poke through it near the edge of the frame.
Peel up the black tape securing the silver ground strap to the metal framework.
Turn the iPod over and peel the orange click wheel ground tab up from the metal framework.
Carefully push the logic board away from the metal framework. Use the squares as indicators of where to push. The logic board is secured to the framework with mild adhesive; be careful not to bend the logic board by pushing too much in any one spot.
The framework should now be free from the rest of the iPod.
Use a small iPod opening tool to flip up the black plastic tab holding the orange click wheel ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
Use a small iPod opening tool to loosen the click wheel cable from the logic board. Be careful not to bend the cable too much, or the electronics on the cable could be damaged.
Disconnect the click wheel cable from of its connector, and lift the entire click wheel assembly away from the logic board.
The click wheel should now be separate from the rest of the iPod.
Use a small iPod opening tool to flip up the brown plastic tab holding the orange hard drive ribbon in place. The brown tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the orange hard drive ribbon cable directly out of its connector. The cable may be attached to the logic board with some adhesive. If the cable doesn't immediately come free, carefully pull up on the cable to loosen the adhesive.
Logic board remains.
95 other people completed this guide.
3 Comments
Step 20 images aren't loading on this page.....
Step 20 images aren't loading on this web page.....
would i loose my music replacing the LC board on the iPad video?
