Image #1 Image #2
Add Note Edit Step 17  ¶
  • De-route the speaker cable from the left side of the battery case.
  • De-route the Wi-Fi antenna through its channel in the speaker assembly.
Image #1 Image #2
Add Note Edit Step 18  ¶
  • Lift the speaker assembly and push it forward until the ports clear the bottom side of the lower case.
  • Remove the speaker assembly from the rear panel assembly.
Image #1 Image #2
Add Note Edit Step 19  ¶
  • The battery is held to the rear panel by an excessive amount of adhesive. Proceed with patience and caution.
  • Use the flat end of a spudger to gently pry the battery up from the the lower case.
  • Gently continue to enlarge the gap by wiggling the spudger and running it along the right side of the battery.
  • Continue to pry until the right side of the battery is free from the rear panel.
Image #1 Image #2
Add Note Edit Step 20  ¶
  • Insert the flat end of a spudger under the top edge of the battery and continue to separate the adhesive.
  • Continue doing so until the top of the battery is free from the rear panel.
Image #1 Image #2
Add Note Edit Step 21  ¶
  • When there is enough clearance, use your hands to peel the battery off any adhesive still securing it to the rear panel.
  • Remove the battery from the rear panel.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Metal Spudger
T5 Torx Screwdriver
$6.95 · 50+ In stock
Plastic Opening Tools
Related Products
iPad Display Clip Set
$19.95 · 8 In stock
iPad Wi-Fi/3G Battery
$49.95 · 20 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
