Page 1 of 1
iMac Intel 20" EMC 2133 and 2210 LCD temperature sensor/cable installation/replacement
User-Contributed Guide
This guide is not managed by iFixit staff.
- Author: Richdave
- Time required: 30 minutes
- Difficulty: Moderate
The purpose of this guide is to show where the LCD temperature sensor and cable are located so they can be replaced if necessary
Sections
- Access Door 1 step
- Glass Panel 2 steps
- Front Bezel 3 steps
- Display Panel 5 steps
- LCD temperature sensor/cable installation 2 steps
- View:
- Paginated
- Full width
Edit Step 2
Glass Panel
The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
Stick two suction cups to opposing corners of the glass panel.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
Edit Step 3 ¶
Gently pull the glass panel straight up off the iMac.
The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
Edit Step 5 ¶
The front bezel is still attached to the iMac by the microphone cable.
Gently lift the front bezel from its top edge off the rear case. It helps to use your thumbs to push down very gently on the corners of the display.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
When reinstalling the front bezel, start at the lower edge and make sure it is flush with the rear case before lowering the top edge onto the iMac.
Edit Step 11 ¶
With the display panel still lifted, disconnect the four inverter cables.
During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush.
During reassembly, the order of the inverter cables is interchangeable within each socket.
Edit Step 12
The LCD temperature sensor is located on the rear of the display panel in the top right corner when viewed from the rear. It is under the black foil about 40mm (1 1/2 in) from the top edge of the panel.
Lay the display panel face down on a cleared surface ensuring nothing is under the panel that may damage it.
Carefully cut a small nic in the foil at the top right corner and gently peel back at an angle to expose the sensor. It will have a foam pad stuck over it.
Gently peel the foam off the sensor to reveal the PCB assembly.
The Sensor is held in place with a small adhesive pad so to remove it, gently pry it up from one edge with a plastic spudger or similar. I recommend NOT using metal tools here.
Disconnect the cable to remove the sensor
Quality Tip When installing the sensor, ensure the connector is well seated and you don't put the connector or cable under tension as this may cause them to separate after reassembly of the system
Edit Step 13 ¶
Note the routing of the cable. It runs up the right side of the display panel and under the edge of black plastic PSU guard adhered to the display panel
If you need to replace the cable, gently lift the right edge of the black PSU guard and carefully peel the cable off the adhesive backing on the guard.
This guide has been completed 1 time.
Page 1 of 1
