Page 1 of 1
iMac Intel 20" EMC 2105 and 2118 Optical Drive Replacement
Replace the optical drive in your iMac Intel 20" EMC 2105 and 2118.
- Author: Walter Galan
- Difficulty: Moderate
Replace a broken optical drive to read compact disks.
Sections
- Access Door 1 step
- Front Bezel 6 steps
- Lower EMI Shield 2 steps
- Display 7 steps
- Optical Drive 7 steps
- Optical Drive Replacement 11 steps
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 3
Re-orient your iMac so it sits upright on the stand.
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
Edit
Step 4
Lay your iMac stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Edit
Step 11
Peel back the EMI tape from the two vertical edges of the display.
During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
Edit
Step 14
Disconnect both inverter cables from the inverter board.
These connectors are seated very tightly in their sockets. It is helpful to use your fingernails or the tip of a spudger to push the ears on either side of the connectors to dislodge them from their sockets. A small pair of hemostats helps a lot.
Edit
Step 19
Use the flat end of a spudger to pry the optical drive ribbon cable connector up off the logic board.
The connector is most easily removed when prying from the top or bottom of the connector.
Bend the optical drive ribbon cable back away from the logic board.
Be very careful when moving the optical drive ribbon cable as it is delicate and easily ripped.
Edit
Step 20
Apple's "engineers" didn't learn much about deflection and material stiffness when they went to "college", so this optical drive is particularly difficult to remove because the bracket flexes too much. The next few steps require some patience and a good amount of force.
Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
The wedge shape of the spudger may cause it to slip out of the gap toward yourself. Be sure to press the spudger in toward the rear case while squeezing the release tab.
This guide has been completed 17 times.
Page 1 of 1
