iMac Intel 17" Front Bezel Replacement
Replace the front bezel in your iMac Intel 17".
  • Add Note x
Use this guide to completely strip down your front bezel.
Sections
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Access Door  ¶
  • Loosen the two captive Phillips screws securing the access door to the iMac.
  • Remove the access door from the iMac.
first image
Add Note Edit Step 2 — Front Bezel  ¶
  • Remove the following four screws:
    • Three 6 mm T8 Torx.
    • One 8 mm T8 Torx.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Flip your iMac over and lay it stand-side down on a flat surface.
  • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the Front bezel up with your index fingers.
  • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Re-orient your iMac so it sits upright on the stand.
  • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
  • Push the card toward the top of the iMac to release the front bezel latch.
  • Pull the front bezel away from the rear case.
  • Repeat this process for the other side of the front bezel.
  • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
  • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
first image
Add Note Edit Step 5  ¶
  • Lay your iMac stand-side down on a table.
  • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
  • Lay the front bezel above the rest of the iMac.
first image
Add Note Edit Step 6  ¶
  • If necessary, remove the piece of kapton tape(it is ok to toss this) wrapped around the microphone and camera cables.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Disconnect both the camera and microphone cables.
first image
Add Note Edit Step 8 — Camera Board  ¶
  • Remove the strip of tape covering the camera board.
first image
Add Note Edit Step 9  ¶
  • Remove the two T6 Torx screws securing the camera board to the front bezel.
first image
Add Note Edit Step 10  ¶
  • Lift the camera board out of the front bezel.
first image
Add Note Edit Step 11 — Microphone  ¶
  • Use a spudger to pry the microphone off the adhesive holding it to the front bezel.
first image
Add Note Edit Step 12 — Front Bezel Replacement  ¶
  • Front bezel remains.
For more information, check out the iMac Intel 17" device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
