Page 1 of 1
iMac G5 17" Model A1144 Front Bezel Replacement
Replace the front bezel in your iMac G5 17" Model A1144.
- Author: Andrew Bookholt
- Difficulty: Moderate
Front bezel damaged beyond repair? Use this guide to replace it.
Sections
- Access Door 2 steps
- Front Bezel 7 steps
- Camera Board 3 steps
- Microphone 1 step
- Front Bezel Replacement 1 step
- View:
- Paginated
- Full width
Edit Step 6 ¶
Re-orient your iMac so it sits upright on the stand.
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
This guide has been completed 1 time.
Page 1 of 1
