iMac Intel 17" Hard Drive Replacement
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
- Author: Walter Galan
- Difficulty: Moderate
Upgrade your hard drive to gain more storage space!
Sections
- Access Door 1 step
- Front Bezel 6 steps
- Display 6 steps
- Hard Drive 5 steps
- Hard Drive Replacement 2 steps
Tools
Tools (continued)
Relevant Parts
- View:
- Single page
Edit
Step 3
Flip your iMac over and lay it stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the Front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Edit
Step 4
Re-orient your iMac so it sits upright on the stand.
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Page 1 of 3
