iJDMTOY Lexus IS F-Sport LED Fog Lights Installation
  1. iJDMTOY Lexus IS F-Sport LED Fog Lights Installation, F-sport fog lights: step 1, image 1 of 2 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation, F-sport fog lights: step 1, image 2 of 2
    • Turn wheel and open wheelbase plastic cover to access back of fog lights.
  2. iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 2, image 1 of 2 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 2, image 2 of 2
    • Remove fog lamp support bracket.
  3. iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 3, image 1 of 3 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 3, image 2 of 3 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 3, image 3 of 3
    • Remove fog lamp location plastic insert.
    • Use one hand to support the plastic insert in front and use another hand to push it out.
    • You may notice there is a slight gap when you put back the LED fog lamp....this is normal!
  4. iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 4, image 1 of 1
    • Replace back with the new iJDMTOY Lexus IS250 IS350 F-Sport LED FOg Lights.
  5. iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 5, image 1 of 2 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 5, image 2 of 2
    • Insert LED fog light starting with the corner that has the longest tab. Gradually ease the LED fog light in with the middle length tabs. Push the short tab at the end to lock.
  6. iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 6, image 1 of 3 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 6, image 2 of 3 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 6, image 3 of 3
    • Locate stock LED DRL adapter below headlamp and unplug.
    • Use the middle wire and striped wire. Tap red wire of the LED fog lights to the middle wire and tap black wire of the LED fog lights to striped wire.
  7. iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 7, image 1 of 3 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 7, image 2 of 3 iJDMTOY Lexus IS F-Sport LED Fog Lights Installation: step 7, image 3 of 3
    • Test to see if the Lexus F-Sport LED fog lights work.
    • Repeat the process on the other side.
It's very straightforward to install iJDMTOY 2014 Lexus IS F-Sport Fog Lights!
4 other people completed this guide.
Eric Wu
3,357 Reputation
23 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 41
All Time: 3,945
