iDea USA CT 1020 Screen Replacement
  1. iDea USA CT 1020 Screen Replacement, Screen: step 1, image 1 of 1
    • Start by powering off the device.
    • Place the device on a clean surface with the screen facing down.
  2. iDea USA CT 1020 Screen Replacement: step 2, image 1 of 2 iDea USA CT 1020 Screen Replacement: step 2, image 2 of 2
    • Gently apply pressure to the back of the device where the backing case and screen meet.
  3. iDea USA CT 1020 Screen Replacement: step 3, image 1 of 2 iDea USA CT 1020 Screen Replacement: step 3, image 2 of 2
    • Using a spudger or an iFixit opening tool, lift and release the camera assembly ZIF tabs.
    • Gently pull the ribbon cable free.
    • Repeat this for the other tab.
  4. iDea USA CT 1020 Screen Replacement: step 4, image 1 of 3 iDea USA CT 1020 Screen Replacement: step 4, image 2 of 3 iDea USA CT 1020 Screen Replacement: step 4, image 3 of 3
    • Remove the disconnected camera by simply pulling it out of its socket.
    • Remove eight 25mm JIS #00 screws securing the motherboard.
    • The battery is glued to the back of the screen. Gently pry the battery off the screen, being careful not the bend the battery.
  5. iDea USA CT 1020 Screen Replacement: step 5, image 1 of 1
    • Remove ten 25mm JIS #00 screws securing the screen.
  6. iDea USA CT 1020 Screen Replacement: step 6, image 1 of 2 iDea USA CT 1020 Screen Replacement: step 6, image 2 of 2
    • Wedge the edges of the opening tools into the gap between the screen and the screen casing.
    • Be very careful while prying the screen from its casing to avoid damage.
Nathanael Carlson
183 Reputation
1 Guide authored
IUPUI, Team S1-G3, Freund Spring 2018 Member of IUPUI, Team S1-G3, Freund Spring 2018
IUPUI-FREUND-S18S1G3
3 Members
4 Guides authored
One Comment
SOOOOO GOOD , Well done
Nathanael Carlson - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 153
