iDea USA CT 1020 Front & Rear Camera Assembly Replacement
  1. iDea USA CT 1020 Front & Rear Camera Assembly Replacement, Front & Rear Camera Assembly: step 1, image 1 of 1
    • First, power down the tablet to avoid the chance of electrical shock or damaging the machine during repair work
    • Place the tablet on a clean surface with the screen down
  2. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: step 2, image 1 of 2 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: step 2, image 2 of 2
    • Remove the back plastic casing of the tablet by releasing the plastic clips with a plastic opening tool or a spudger.
    • Be cautious and take your time here; the plastic clips are quite fragile.
  3. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: step 3, image 1 of 1
    • Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
    • Gently pull the ribbon cable free.
  4. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: step 4, image 1 of 2 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: step 4, image 2 of 2
    • The camera is held in place by adhesive material on the back of the camera
    • To complete removal, peel the camera off the mother board
David Lawrence
109 Reputation
1 Guide authored
IUPUI, Team S1-G3, Freund Spring 2018 Member of IUPUI, Team S1-G3, Freund Spring 2018
IUPUI-FREUND-S18S1G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 107
