iBook G4 12" 1.33 GHz Hard Drive Replacement
  • Add Note x
  • x 75
You can install hard drives up to 9.5mm thick.
Sections
Files
Tools
first image
thumb image 1
thumb image 2
  • Lay your iBook upside down on a flat surface.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2 — Keyboard  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
first image
Add Note Edit Step 3  ¶
  • Remove the four silver Phillips screws that secure the RAM shield.
first image
Add Note Edit Step 4  ¶
  • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
  • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
first image
Add Note Edit Step 5 — Lower Case  ¶
  • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
first image
Add Note Edit Step 6  ¶
  • Remove the three newly-revealed Phillips screws.
first image
Add Note Edit Step 7  ¶
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
first image
Add Note Edit Step 8  ¶
  • Remove the three hex screws using a T8 Torx screwdriver.
  • The shorter screw is in the center of the computer.
first image
Add Note Edit Step 9  ¶
  • Remove the two 4.5 mm Phillips screws on either sides of the battery contacts.
first image
Add Note Edit Step 10  ¶
  • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
  • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
first image
Add Note Edit Step 11  ¶
  • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
first image
Add Note Edit Step 12  ¶
  • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
first image
Add Note Edit Step 13  ¶
  • Continue to run the spudger around the front right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
first image
Add Note Edit Step 14  ¶
  • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
first image
Add Note Edit Step 15  ¶
  • The front and sides of the lower case are now free.
  • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
  • It may be helpful to jiggle the case up and down.
first image
Add Note Edit Step 16  ¶
  • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
first image
Add Note Edit Step 17 — Bottom Shield  ¶
  • Remove the following 4 screws from the bottom shield:
    • Two 3 mm Phillips.
    • Two 7.5 mm Phillips.
first image
Add Note Edit Step 18  ¶
  • Lift the bottom shield off.
first image
Add Note Edit Step 19 — DC-In Board  ¶
  • Remove the two Phillips screws securing the DC-In board, removing tape as necessary.
first image
thumb image 1
thumb image 2
Add Note Edit Step 20  ¶
  • Deroute the cable from around the optical drive, removing tape as necessary.
  • Disconnect the DC-In cable from the logic board and angle the DC-In board out of its compartment.
first image
Add Note Edit Step 21 — Upper Case  ¶
  • Remove the two 3 mm Phillips screws inside the left edge of the battery tray.
first image
Add Note Edit Step 22  ¶
  • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
  • Turn over the computer and open it.
  • Use the flat side of a flathead screwdriver to remove the small magnet covering a screw near the middle of the computer.
first image
Add Note Edit Step 23  ¶
  • Remove the following 7 screws from the edges of the keyboard area.
    • Three 2 mm Phillips along the right edge.
    • One 4.5 mm Phillips underneath where the magnet was.
    • One 6 mm Phillips with a small head in the lower left corner.
    • Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle.
first image
Add Note Edit Step 24  ¶
  • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
  • Carefully lift the upper case slightly and move it toward the front of the computer to reveal the trackpad connector. Use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
  • After disconnecting the track pad connector, carefully rotate the upper case away from you and rest it against the display.
first image
Add Note Edit Step 25  ¶
  • The connectors at the ends of the following cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
  • Use the sharp end of a spudger to disconnect the speaker cable connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 26  ¶
  • Using the sharp end of a spudger, disconnect the connector for the blue and white power cables. Again, be careful to pry up only on the connector.
  • The key is to apply force in two directions, down to keep the surface board connections intact, up to release the connector.
  • The upper case is now free and can be removed from the computer.
first image
Add Note Edit Step 27 — Top Shield  ¶
  • Remove the fifteen 3 mm Phillips screws securing the top shield to the computer.
first image
Add Note Edit Step 28  ¶
  • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
first image
Add Note Edit Step 29 — Hard Drive  ¶
  • Remove the metal hard drive retaining bracket from the computer.
first image
Add Note Edit Step 30  ¶
  • Remove the four Phillips screws securing the hard drive to the metal framework.
first image
Add Note Edit Step 31  ¶
  • Slightly lift the hard drive from the free end and pull the hard drive straight away from the connector.
first image
Add Note Edit Step 32 — Hard Drive Replacement  ¶
  • Remove the hard drive brackets from the left and right sides of the hard drive.
first image
Add Note Edit Step 33  ¶
  • Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
first image
Add Note Edit Step 34  ¶
  • Pull the plastic hard drive connector straight away from the hard drive.
  • This is a bit tricky. Try rocking the connector gently while pulling with even pressure. If you bend the pins, do your best to straighten them, using the hard drive connector as a guide.
  • Hard drive remains.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
For more information, check out the iBook G4 12" 1.33 GHz device page.
Did you successfully follow this guide?
This guide has been completed 75 times.
