Image #1
Add Note Edit Step 33  ¶
  • Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
Image #1
Add Note Edit Step 34  ¶
  • Disconnect the hard drive connector from the hard drive.
  • This is a bit tricky. Try rocking the connector gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 20 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 26 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Device Products
100 GB 9.5mm ATA Hard Drive
$99.95 · 1 In stock
G4/MagSafe AC Adapter End
$4.95 · 46 In stock
iBook G4 14" DC-In Board
$29.95 · 7 In stock
