iBook G4 12" 1.33 GHz Optical Drive Replacement
  • Add Note x
  • x 15
Upgrade or replace the CD, DVD, combo or SuperDrive.
Image #1 Image #2
  • Lay your iBook upside down on a flat surface.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
Image #1 Image #2
Add Note Edit Step 2 — Keyboard  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Image #1
Add Note Edit Step 3  ¶
  • Remove the four silver Phillips screws that secure the RAM shield.
Image #1
Add Note Edit Step 4  ¶
  • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
  • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
Image #1
Add Note Edit Step 5 — Lower Case  ¶
  • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
Image #1
Add Note Edit Step 6  ¶
  • Remove the three newly-revealed Phillips screws.
Image #1
Add Note Edit Step 7  ¶
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Image #1
Add Note Edit Step 8  ¶
  • Remove the three hex screws using a T8 Torx screwdriver.
  • The shorter screw is in the center of the computer.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 20 In stock
Related Products
iBook G4 12" 24x Combo Drive
$79.95 · 4 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
