Changes to revision 6546:
Edit by Miroslav Djuric:
- Deleted
- Added
- Unchanged
Changes to text
| [* standard] The phone is generally quite solid with front facing buttons that look great and give a good feeling when depressed. |
| [* standard] The cover |
| [* standard] Also, the sliding mechanism is definitely not as smooth as the XPERIA X1’s nor the G1’s. The bottom of the screen module scrapes over the keys, resulting in an inelegant transition. |
| [* standard] The other interesting thing to note is the four torsional springs implemented just to slide the device. In fact, the small and light cover, uses a dual torsional spring, just to hide the ribbon. |
