Changes to revision 115873:
Edit by Brett Hartt:
- Deleted
- Added
- Unchanged
Changes to text
| [* icon_caution] When working with batteries, you must always remove the negative lead from the battery first, even if the corrosion is only on the positive lead. |
| [* black] Using a |
| [* black] Using a |
| [* black] If the corrosion is preventing you from accessing the nut, use a the other end of the wrench or another scraping tool to scrape some of the corrosion away. |
| [* black] Pull the negative battery cable off of the negative lead. |
