Changes to revision 5461:
Edit by Walter Galan:
- Deleted
- Added
- Unchanged
Changes to text
| [* icon_note] Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly. |
| [* black] Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. |
