Changes to revision 110590:
Edit by Walter Galan:
Deleted
Added
Unchanged
Changes to text
[* black] Insert wisdom hereicon_note] Before disassembling your iPhone, be sure it is powered off.
[* red] Remove the two 3.6 mm Pentalobe screws next to the dock connector.
[* icon_reminder] During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our [product|IF182-019|Liberation Kit] provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
[* icon_caution] The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws
