Changes to revision 112353:
Edit by Phillip Takahashi:
- Deleted
- Added
- Unchanged
Changes to text
| [* red] Mark or note the edges that need to be cut to open the AirPort Express case. |
| [* black] Use a dremel tool with a thin cutting bit to slowly cut around the marked edges. Cut evenly and make several shallow passes to ensure that you don't accidentally cut into any of the components inside. |
| [* icon_caution] If you see sparks while cutting, it means you are cutting through the EMI shields. Reduce your cutting depth immediately to prevent further damage. |
| [* icon_caution] Be especially cautious when cutting next to the LED light, as the power wires are right next to the case wall. |
