Changes to revision 102802:
Edit by Jake Devincenzi:
- Deleted
- Added
- Unchanged
Changes to text
| [* black] '''iPod Nano |
| [* green] Good: Once the display is removed, the rest of the disassembly is relatively straightforward |
| [* green] Good: The ribbon cable connectors make it easy to disconnect the display and headphone jack from the logic board. |
| [* yellow] Neutral: The headphone jack and volume buttons are attached to the same ribbon cable and must be replaced at the same time. |
| [* red] Bad: Getting the display off of the device requires the use of a heat gun, as there is a lot of adhesive holding it in place. |
| [* red] Bad: The battery is soldered to the logic board, making replacement of a single component more cumbersome. |
