Changes to revision 102800
Edit by Jake Devincenzi:
Deleted
Added
Unchanged
Changes to text
[* black] '''iPod Nano 6th Generation Repairability: 5 out of 10''' (10 is easiest to repair)
[* green] Good: Once the display is removed, the rest of the disassembly is relatively straightforward.
[* green] Good: The ribbon cable connectors make it easy to disconnect the display and headphone jack from the logic board.
[* yellow] Neutral: The headphone jack and volume buttons are attached to the same ribbon cable and must be replaced at the same time.
[* red] Bad: Getting the display off of the device requires the use of a heat gun, as there is a lot of adhesive holding it in place.
[* red] Bad: The battery is soldered to the logic board, making replacement of a single component more cumbersome.
