Changes to revision 98467:
Edit by David Hodson:
- Deleted
- Added
- Unchanged
Changes to text
| [* black] The next components to install are the LEDs. Light |
| [* icon_note] Note that the two leads are different lengths. Since an LED is a diode, it only allows current to travel in one direction, so it is important to install the correct lead in the correct hole. |
| [* red] The four LEDs belong in each of the four terminals marked LD1 through LD4. |
| [* black] When installing the LEDs, insert the shorter of the two leads into the hole next to the flat part of the printed circle. |
