Changes to revision 51467:
Edit by iRobot:
- Deleted
- Added
- Unchanged
Changes to text
| [* standard] Remove the following 11 screws: |
| [* red] Seven 3 mm Phillips. |
| [* orange] Two 4 mm Phillips. |
| [* yellow] Two 7 mm Phillips. |
| [* standard] While our circles make it look like there are a lot of screws, this machine appears to have fewer screws than the previous MacBook Pro. These screws all attach directly to the solid-piece upper case, which should simplify maintenance a bit. |
