Changes to revision 82752:
Edit by Miroslav Djuric:
Deleted
Added
Unchanged
Changes to text
[* black] iPad 2 Repairability Score - '''6 out of 10''' (10 is easiest to repair)
[* green] The LCD is really easy to remove once the front panel is gone.
[* green] Only standard Phillips screws were used -- no Pentalobular or Tri-Wing funny-business.
[* red] The battery is very securely stuck down to rear case, and you have to remove the logic board to remove it.
[* red] You can't access the front panel's connector until you remove the LCD.
Changes to images
No previous image
Image 1 (added)
