Changes to revision 53535:
Edit by jdub:
- Deleted
- Added
- Unchanged
Changes to text
| [* black] Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables. (*ONLY THE BACK SIDE (OPPOSITE THE SIDE IN WHICH THE RIBBON CABLE IS INSERTED) OF THE CONNECTOR LIFTS UP. Lift up the back side of the connector and then the ribbon cable will slide out easily. IF YOU TRY TO LIFT UP THE SIDE IN WHICH THE RIBBON CABLE IS INSERTED, YOU WILL BREAK THE CONNECTOR!" |
