Changes to revision 72093:
Edit by Andrew Bookholt:
Deleted
Added
Unchanged
Changes to text
[* black] Insert wisdom herePush the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
[* black] Once the two display hinges have cleared the upper case, remove the display and set it aside.
[* black] Keep track of the shims under each of the two display brackets. When installing the display, be sure a shim is installed under each display bracket (against the upper case) as shown in the third picture
Changes to images
Image 2 (old version)
Image 2 (new version)
