Changes to revision 70802:
Edit by David Hodson:
- Deleted
- Added
- Unchanged
Changes to text
| [* black] Nexus S Repairability Score: '''7 out of 10''' (10 is easiest to repair) |
| [* green] Battery is very easily replaceable -- just remove the back cover to swap it out. |
| [* green] The |
| [* green] The |
| [* yellow] A lot of the phone's components are modular, meaning that they're simpler to replace, but will cost more as replacement parts. |
| [* red] Front panel is attached with adhesive instead of screws, so it's harder to take off than on the iPhone. |
| [* red] If you shatter the front panel glass, the LCD has to be replaced as well -- they're fused together. |
