Changes to revision 64168:
Edit by Brett Hartt:
Deleted
Added
Unchanged
Changes to text
[* black] Carefully turn the daughterboard over, making sure to not breaktear the attached cable.
[* black] RemovePull the IR sensorSensor cable straight away from its socket on the daughterboardboard.
[* icon_caution] Be sure that you are not pulling from the connector, not fromon the cables or onas you remove the socket itselfplug from its socket.
[* black] Blu-Ray drive remains.
[* icon_note] If you are replacing the Blu-ray drive, you must use the same daughterboard that came with your PlayStation 3. The daughterboard is paired to the Motherboardmotherboard, and the Blu-ray drive will not work with a foreign board.
