Changes to revision 83730:
Edit by Andrew Bookholt:
Deleted
Added
Unchanged
Changes to text
[* black] Disconnect the two antenna cables from the AirPort Extreme card, the iSight and inverter cables from the left side of the logic board, and the display data cable from the right side of the logic board. (The long thin ones slide out backwards - the black one pops up)
[* icon_note] For A1229 and A1212 models, disconnect the three antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
[* icon_note] For the A1261 model, disconnect the two antenna cables from the AirPort Extreme card and the three connectors highlighted on the logic board.
[* black] Carefully peel the iSight and inverter cables off the top of the left fan and de-route the AirPort antenna cables from the channel in the left speaker.
