Changes to revision 82998:
Edit by Olli:
Deleted
Added
Unchanged
Changes to text
[* black] Use the clear plastic pull tab to gently lift the battery out of the iPhone.
[* black] Be careful when removing the battery with the plastic pull tab. On some units, Apple uses an excessive amount of glue, making it virtually impossible to remove the battery in this fashion (with the tab possibly tearing due to excessive force).
[* black] For batteries that "stick", you could use the iPod opening tool to assist (take extra care whilst doing so).
[* black] Removeicon_caution] Placing back the battery.
[* icon_note] Before reconnecting the battery connector, be
battery:
[* orange] Make
sure the pressureantenna contact (shown in red) is properly positioned next tounder the battery connector.
[* icon_caution] Before reassembly, be sure to clean all metal-to-metal contact points on
[* orange] First fit
the pressure contact as well as its contact point onbattery connector, then place the rear panel with a de-greaser such as windex. The oils on your fingers havebattery into position by folding the potential to cause wireless interference issues.connection cable
battery:
[* orange] Make
