Changes to revision 53423:
Edit by Andrew Bookholt:
Deleted
Added
Unchanged
Changes to text
[* black] Use the clear plastic pull tab to gently lift the battery out of the iPhone.
[* black] Remove the battery.
[* blackicon_note] Before reconnecting the battery connector, be sure the pressure contact (shown in red) is properly positioned next to the battery connector.
[* icon_caution] Before reassembly, be sure to clean all metal-to-metal contact points on the pressure contact as well as its contact point on the rear panel with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
