Changes to revision 103001:
Edit by jragatz:
In Patrol
Deleted
Added
Unchanged
Changes to text
[* black] Removing the lower antenna/speaker enclosure from the bottom of the phone.
[* black] The improved audio chamber aids in clarifying sounds leaving the iPhone, including calls via speakerphone as well as music played through the speaker inside this housing.
[* black] Apple hasn't made taking the iPhone 4 apart very hard so far: no 5-point Torx bits or fragile clips to be seen. * On some iPhone 4s, the two screws used to secure the rear face (removed in Step 1) are 5 point screws instead of Phillips. Mine is one of those.*
