Changes to revision 134538:
Edit by Puru:
In Patrol
Deleted
Added
Unchanged
Changes to text
[* black] Luckily, the battery can be easily removed once the back panel assembly is out of the way.
[* black] In some cases, the glue underneath the battery (as marked in the picture) seems rigidly holding the battery resulting almost impossible to pull-up as expected. In such case, using Spudger, it can be spade up gradually. Be careful not to use too much force causing some damages to the battery itself.
[* black] The 3.7V 1420 mAh Li-Polymer battery allows for up to 7 hours of talk time on 3G or up to 14 hours on 2G.
[* black] The battery connector is different than the one in the 3G and 3GS. Fortunately, the battery is not soldered to the logic board. This will make battery replacement on the iPhone 4 fairly easy to accomplish.
[* black] The plastic pull tab for the battery says "Authorized Service Provider Only."
