Changes to revision 59336:
Edit by Richard Grossman:
Deleted
Added
Unchanged
Changes to text
[* black] Remove the following ten screws securing the lower case to the upper case:
[* orange] Three 13.5 mm Phillips screws.
[* red] Seven 3 mm Phillips screws.
[* black] When reassembling the computer:
[* black] Replace and lightly tighten the 3 13.5 mm Phillips screws.
[* black] Replace and lightly tighten the 2 3 mm Phillips screws at the left and right sides of the case.
[* black] Replace and lightly tighten the remaining 5 3 mm Phillips screws.
[* black] Starting clockwise from any corner, further tighten each screw to the max possible while exerting only slight downward pressure. When the screwdriver "pops", move on.
